Fuel pump circuit getting hot
Old Nov 23, 2004 | 10:05 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
If my car runs for even a short length of time the fuel pump circuit gets hot. I have replaced all the relays, the oil pressure switch, and the fuel pump, even tried a different MAF sensor but none of that helped.
I concerned that the wires may melt. Has this happened to anybody elses car, and what did you do to resolve it?
John
Old Nov 23, 2004 | 10:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When you say the circuit gets hot, what exactly do you mean? Are the wires getting hot, the relays?
Old Nov 24, 2004 | 05:04 AM
The wires are getting hot, after driving around for 20 minutes or so, I would guess that the wires are 110-120 degrees.
At first I thought it was ambient heat from the radiator, but the wires are heating up long before the radiator does.
Old Nov 24, 2004 | 12:02 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Are you using a stock fuel pump or aftermarket?
Old Nov 24, 2004 | 02:28 PM
I found the problem, or at least i think so, circuit 120( the tan wire w/ white stripe) is shorted to ground, if I put an ohm meter across cir 120 and the neg bat terminal, the meter zeros.
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
