computer trouble
Old Dec 12, 2004 | 04:32 AM
scooted45's Avatar
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
computer trouble
I know this is tpi board, but I need to know why my 88 5.7 computer dosn't start the engine when swapped w/ from '86 5.0 tpi to '88 5.7 tpi. thanks
Old Dec 12, 2004 | 06:42 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: computer trouble
I need you to explain the whole scenario.
-- Joe
Old Dec 14, 2004 | 07:17 AM
scooted45's Avatar
I have an '86 Iroc clone that according to the vin code use to be a six popper Sport Coupe. The 5.0 that was in it ran great but a little rich. The 5.0 is tpi and looks like an '86 engine (see pic). The swap looks complete and professional as though dealer installed. So I rebuilt a L98 5.7 from an '88 GTA and dropped it in. Street strip cam, mild head & intake port & polish, roller rockers, gear drive, headers and Accel ignition. Now the 5.7 computer won't start the car but the old 5.0 one will. I kept the same harness because the Painless Wiring harness was the same part # for '86 & '88. The '88 computer clips right in. There is also a Bosch unit attatched to the computer w/ it's own harness, what is it? Can the 5.0 unit be programed to run my 5.7 right? The car runs great with the 5.0 computer but I can't help think I'm missing out on some power. Thanks for reading, any help
Old Dec 14, 2004 | 07:48 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The 88 ecm MAY have vats and that may be the problem.
Try removing the memcal from the 88 computer and put it in teh 86.. See if it will fire the car. If so, the ECM is fried. If not, its VATS.
You should start considering prom tuning if your engine is modified.
-- Joe
Old Dec 15, 2004 | 06:50 AM
scooted45's Avatar
comp trouble
The donor car didn't have vats
Old Dec 15, 2004 | 05:20 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Both the 88 and 86 computers "should" be the same. The issue could be the memcals or the ECM's.
do what anesthes said and see what happens.
mrbird
Oct 20, 2015 03:43 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
Lmancha96
Sep 25, 2015 08:11 PM
