Starting Issues
Old Dec 20, 2004 | 09:52 AM
Firebird90V6's Avatar
Starting Issues
Hey my 85 TPI car is having some issues with starting. I hit the key and the fires up and dies right away. I hit the key again and it fires up runs for a second and dies. Hit a third time and it fires up and runs but every once in a while it seems as if the car is surging looking for an idle. Im thinking its the TPS sensor but im not sure anybody else have any ideas?
Old Dec 20, 2004 | 01:51 PM
20N!N's Avatar
Car: '88 IROC
Engine: 350cid
just went through a lot of this myself. you can do a search for throttle posistion sensor and find about the correct ohms the sensor should be set at (~.54 as I recall).
My best advice though is check your IAC sensor. 25$ for the part at Autozone and you'll need a large crescent wrench (or pay the 30$ for the specific open-end). I chased the exact same thing and that's where I ended up. If it doesn't help, then I'd start chasing your TPS sensor, plugs, wires, ignition, etc. I went in this exact reverse order.
Old Dec 20, 2004 | 02:57 PM
Thanks for the information. My ignition and plugs, wires, all that stuff was all replaced and still did it. Im not launching a check engine code either so that doesnt help. Once the car running and gets warmed up i dont have this problem anymore. Thanks for the input for 25 bucks ill just replace the IAC and see where that puts me, i mean it is 20 years old now so its about time for a replacement.
Old Dec 23, 2004 | 01:51 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
If it's only when the engines cold, don't rule out the coolant temp sender, either.
Old Dec 23, 2004 | 07:54 PM
coolant temp sensor eh ill keep that in mind thanks man.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
