Injector Size
Old Jan 11, 2005 | 04:31 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Injector Size
What hp numbers could 32# injectors make? With an FMU because its turbocharged. Thanks
Old Jan 12, 2005 | 07:50 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
With the fuel pressure set at the rated pressure for the 32#/hr injectors, you can make between 340 HP (80% DC) and 384 HP (90% DC) at the flywheel.
If the FMU can increase the fuel pressure by 10psi, then you can make about 10% more HP above those numbers.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
