Cant figure out....
Old Jan 18, 2005 | 11:58 AM
formula1988's Avatar
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
Cant figure out....
I just baught a 1988 formula 3 weeks ago. It seems to have problems starting. The guy i baught it from said it was beacause of a week battery. I got a new battery for it and it didnt help. It also stalls some times. WHen i start it, if i push the gas at all, it dies. And sometimes when driving it if i give it the gass it fells like it is going to die. When i go to start it, it takes about 6-7 secs to start. I also got a new distributor cap and the spark plugs were fine. The guy i baught it from also said it had bad gas in it. What do you guys think is the problem.
Old Jan 18, 2005 | 02:15 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
Check fuel psi and smell the gas.. if it stinks unlike normal gas that may be the problem..
Old Jan 18, 2005 | 03:01 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
bought
start it up and let it idle and warm up and see if it does the same after warmed up.
also even though the plugs look ok doesn't mean they are ok. i would put new wires and plugs on it and get some new gas in it.
Old Jan 18, 2005 | 05:11 PM
Engine: l98 350 tpi
88
i have went through 3 tanks of gas. Ill get wires and plugs and try that. The exhaust smells alittle rich. It still has the same problem when its warm or when its not. I was thinking it was getting to much fuel and fludding. I dont know. But this morning it took forever to get started. It would start then it would idle low and then die. i really dont want to spend 400$ on trying to figure out the problem. Alot of you guys on this site are crazy smart. So thanks for any suggestions. it helps alot.
Old Jan 18, 2005 | 05:14 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
try to check timing. Also check Idle Air Control Valve.
Old Jan 19, 2005 | 08:44 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
When mine did similar stuff, it was the fuel pump in it's death throes. First thing, check fuel pressure. I'd start cheap and simple. Replace the fuel filter. That is a commonly overlooked item that can cause problems like these.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
