Broken and Lost Fuel Injector Locks
Old Jan 19, 2005 | 05:08 PM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
Well, in the process of my retrofit of TPI on my LG4, I decided I was going to remove my injectors for fresh o-rings. I neded up with some busted knuckles... which heal
... and busted injector locks. I also saw there were 2 injector locks missing from this set too Beffuddled the bejesis out of me...
SO I went to the junk yard in the snow today, and figured the 3.1L motors had the same injector locks... well, they don't. Does anyone know a good resource for these parts?
Old Jan 19, 2005 | 05:42 PM
Mark 89Formula's Avatar
Got a pack of them from the dealer a few years back. I don't remember if they had to be ordered but they were pretty cheap. That would be my first choice since the thin metal these things are made of doesn't hold up well to repeated use.
Old Jan 19, 2005 | 07:35 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
You really don't need the clips as once the fuel rail is bolted down to the intake base there is no where for the injector to go. You can't really pull the injector up or down without the clip anyway so allignment really is not an issue. You can still buy the clips at many differenet parts stores or GM. I see you changed the o rings which is a good idea. The best ones I have used are the blue ones from GM. They are slightly oversized or maybe they are just puffy, but they are very tough and give an awsome seal. Don't try buying a generic o ring, as it doesn't pay to have fuel shooting around at 50 psi in the engine bay. Make sure you replace the o rings on the fuel supply and return lines as well where they come off the fuel rail. Its cheap insurance......
Old Jan 19, 2005 | 09:46 PM
86BirdSE's Avatar
thanks for the tip... I bought a complete tpi gasket set from Napa, and it contained some black o-rings... I'm not real impressed with em, they seemed as hard as the 18 yr old ones... a little armor all softened them up a bit.
Old Jan 20, 2005 | 12:49 AM
Ne14RoxCJ's Avatar
Car: '85 K5 Blazer/Jeep CJ
Engine: 350 TBI/350 TPI
Transmission: 700R4/BW W/C T-5
Borg Warner 28417. I got the clips from an O'Reilly Auto parts.
Old Jan 20, 2005 | 06:09 AM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Use tranny fluid. It acts as a good lubricant and will also swell the rubber making for a tighter fit once everything is assembled.
bryan623
Mar 22, 2021 06:43 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
