Stealthram w/ stock TB?
Old Feb 12, 2005 | 08:01 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
Is anyone using a stock TPI TB on a stealth ram? If so, did u run into any issues of the linkage hitting the driver's side fuel rail?
-Dave
Old Feb 12, 2005 | 08:31 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Stealthram w/ stock TB?
-Dave
I did not have any issues, but others did. If you do a search you will get some better answers.
Old Feb 13, 2005 | 11:56 AM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
I had the linkage hit the fitting on the front of the fuel rail, which was keeping the throttle from closing all the way. 90 seconds with a die grinder fixed it.
Old Feb 13, 2005 | 01:26 PM
Engine: 383, 327
Yep, did a search and saw that others had the same trouble I did.
A little grinding with the bench grinder and it seems to work without hitting now.
Thanks!
-Dave
batchfire
Feb 13, 2005 05:03 PM
Skipit
Sep 21, 2002 07:11 PM
