man i lucked out
Old Feb 16, 2005 | 05:53 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
man i lucked out
when i went to put my holley 58 on my car i was getting the bypass off the bottom of the 20 year old stock tb that had never been touched. i broke 4 of the bolts off and were left with 2 bolts, then when i tried to pry the crossover off it broke in half, but i was ably to salvage the vacuum part for the iac and seal it with two bolts and some silicone. damn i was lucky, 20 year old water crossovers are not fun
Old Feb 16, 2005 | 06:09 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
same thing happened to me on saturday when i put my 52 on, only i broke 5 of the 7 bolts(good thing new ones came with it). Decided to beat water passage off with hammer....it broke. i was able to salvage the IAC part of it and ive had the coolant bypassed for the last 2 years.
Old Feb 16, 2005 | 06:11 PM
i guess after years of heating and cooling and water running through them it takes a lot out of them
Old Feb 16, 2005 | 06:20 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
yeh, used vice grips and the broken bolts came right out, go figure. by the way, did you notice any difference with the 58. i heard that they mess with the timing of the transmission shifts, making them shift too soon.
Old Feb 17, 2005 | 01:18 AM
no it actually is running great, i had heard that i would have throttle boog, but in fact my throttle response has been better and my idle is perfect, shifts are great too
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
HoosierinWA
Oct 7, 2015 10:15 AM
