superram hardware
Old Mar 11, 2005 | 02:21 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
superram hardware
I got a really good deal on an accel superram but it didnt come with any hardware for the plenum to runners does anyone know where i could pick some up? thanks!!!!!!
Old Mar 11, 2005 | 06:25 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Do you just need the 16 ¼-28 x ¾ 12 pt Head bolts that attach the runners to the underside of the plenum? I'd try giving Lingenfelter a call first. I don't know if they will help source them though.
1/4"-28 is a fine thread pitch because normally 1/4 threads are a 20 pitch. This makes it a trickier find.
ARP makes a brake hat bolt kit contaning 48 1/4"-28x3/4" 12 pt bolts in a black oxide finish. The part number is 300-0803, but it's $103 which equals out to over $2 a bolt. There's got to be a better source that drops the price to about $1 a bolt. If you want to go to a cap screw (hex head bolt) this will maybe work. Barnhill does not list the a 12 pt. 1/4" NF in a 3/4" length, only in a 7/8". Maybe someone else knows the answer to your question right offhand.
I found another source using a search engine. Price is not listed but here's the link, http://www.rcdengineering.com/price_f.html
Bingo! Here's a source and there chrome-plated and only $0.89 a pop, http://www.afchromebolts.com/catalog_12point.html. Here's another, http://www.farschrome.com/capscrews/12pointcapscrew.htm
Do you have the install .doc file that Lingenfelter published to update those horrible original instructions? Did you get the throttle bracket in the deal?
BTW, what cam are you going to? I like your setup.
Old Mar 11, 2005 | 03:40 PM
Engine: 355, 305
Axle/Gears: 3.73, ?
thanks for all the help. im using the same crane cam as in the sig for now and no i didnt get the throtte bracket i was just lookin at it today wonderin how the stock one was gunna work any ideads on that?
Old Mar 11, 2005 | 04:53 PM
Jade Grey's Avatar
Engine: 305TPI
I think Ominous_87 knows how to modify a stock one to work. I would check Superram related threads. Do some searching. I know it has been discussed before.
The problem is that the throttle body mounting surface on the Superram is angled down farther than a stock plenum. It puts at least one of the cables in a semi-bind if you reuse the stock bracket.
Eventually when I build my 355, IROCZZ3's Superram intake will live again.
Old Mar 12, 2005 | 01:07 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
Pac J
May 17, 2020 10:44 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
sjorgens
Oct 1, 2015 07:54 PM
dbrochard
Sep 25, 2015 04:56 PM
