oil pump drive help
Old Mar 26, 2005 | 10:24 PM
SpeeDeamon's Avatar
Car: 1988 TPI 350 and a few add-ons
oil pump drive help
Im installing a new MSD distributor and its not seating properly. I understand that you have to turn the oil pump drive. Now, what are the steps to do this? Sorry for the rookie type question but Im tryin to learn
Thanks for any help or suggestions.
Old Mar 26, 2005 | 10:36 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Look down the distributor hole. You will see a shaft with a slot on top/ Turn the shaft with a long screwdriver. 1/8 of a turn or so will do it usually. The notch in the bottom of distributor gear must engage after the gear splines onto the cam gear. A little tricky the first time but no big deal.
Old Mar 27, 2005 | 12:17 AM
SpeeDeamon's Avatar
Thanx for the help Floor Guy.
89GTAOz
May 16, 2020 09:31 AM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
mcquigg
Aug 13, 2015 02:26 PM
92camaroJoe
Aug 13, 2015 06:07 AM
