Bad ECM?
Old Apr 11, 2005 | 07:31 AM
MikeS's Avatar
Bad ECM?
I'm stumped on this one... anybody lend a hand?
87 Trans Am (305 TPI) seemed to be normal when parked. Wouldn't do anything but crank the following morning. I've been trying to diagnose the problem, replaced some components in the process, but getting nowhere.
Anyway, I'm getting no spark, and don't believe that the injectors are getting any signal. Can't hear them, and can't register anything at the connectors to them. Also, I can't find any signal on the wires between the distributor and the ECM. It's as if the ECM is not providing any of the 'pulsed' type switching or signals that it should be.
Also, the fuel pump does prime, and I have fuel at the rail.
Don't know what to do except try another ECM....
Any thoughts? I threw some parts at it early on when I realized I had no spark....coil, module, cap, and rotor.
Thanks,
Mike
Old Apr 11, 2005 | 02:26 PM
Noha's Avatar
Car: 850ci
Engine: 12
Transmission: 6Spd
Re: Bad ECM?
Thanks,
Mike
Getting fuel but... do you have volume and pressure..?
hook gauge up to fuel rail jumper aldl terminal g with fused jumper key on to 12 Volts check pressure
do you have 12Volts going to pcm.? did you check pick up coil under rotor..?
Old Apr 11, 2005 | 04:36 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
vats (had same problem with my 89 bird)
Old Apr 12, 2005 | 12:32 PM
MikeS's Avatar
No vats on the '87...
I don't have a fuel pressure gauge, but my crude estimate is that it 'seems' ok...
did not check the pick up coil, as I had no signals to or from the distributor at the ecm.
yes, 12V to the 'puter. Picked up another, I'll try it this afternoon and see if that solves it.
Thanks both,
mike
Old May 10, 2005 | 06:44 PM
MikeS's Avatar
For closure....
bad pickup coil. the coil tested infinite resistance (open), so I put in a new distributor. would have just replaced the pickup coil for cheaper, but couldn't get the roll pin out that holds the drive gear on the end of the distrib. shaft...
you called it noha!
skeltor
Feb 2, 2016 10:37 AM
88rscamar0
Sep 23, 2015 09:08 PM
Billy Decker
Sep 4, 2015 03:46 PM
willyjoejr
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
