Could Rusty Distributor cause jumpy Tach and rough running Pics Inside
Car: 87 Trans Am
Transmission: TKO 600
I have a jumpy tach and the car feels like its misfiring under 2k. I pulled the cap and rotor and found the rust. I've seen some rust on ther cars but not this bad.
Car: 92' RS Camaro
Not sure about that, could be possible.
I would start with Plugs/Wires/Cap/Rotor before worrying about the distributor. After all that if the problem still exsists then I might look into it. Good Luck!
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Mine looks the same way and its just 2 years old... So my vote is no. Check the connection from the distrubtor to the coil, then check the plug wires. I had a slightly burnt wire and the tach jumped around some...
Car: Which one?
Engine: 355
Transmission: 465
Mine came from AZ and it was rusty like that as well. I have a tach hooked up and idle is smooth and so is the tach.
I couldn't figure out how to get that thing apart enough to clean it, or I would have, but apparently it will end up looking like that again anyways, so...
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Check the pickup coil very carefully. Its the yellow and green wores coming out from under the reluctor there in the pic.
Should not be shorted to grd or each other.
U need roughly.350-.5v ac when cranked also.
Very common for the pickup coil insulation to disintegrate over time and/or the yellow/green leads to break near where they exit the coil, directly under the reluctor assembly if u look under it with a mirror or pull the distrib.
later
Jeremy
later
Jeremy
92camaroJoe
Aug 13, 2015 06:07 AM
auto, bad, distributeor, distributor, distributors, inside, jumpy, pickup, plug, problems, rusted, rusty, tach, tpi, wires
