VORTEC heads on stock lower intake???
Old May 12, 2005 | 05:36 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
hi i've seen lots of modification of lt-1 intake on tpi motor...but is it possible to modified stock tpi intake to fit vortec heads...worth it or should pay for SDPC itake adaptor? im running stock 081 LB9 heads on 355cu/in cammed. other sugestion for additional pony and help power at higher rpm...nothing after 4000:S
Old May 12, 2005 | 07:09 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
This has gone on for years. NO The Vortec head intake ports are like .180" higher than standard Gen I 23* SBC heads. It was made possible before the sdpc intake was out but it is not worth your money to try it your self.
Old May 13, 2005 | 06:03 PM
FOX-GTA_89's Avatar
ooooops!!!
sorry...thank you... gonna look for other option possible.
Old May 13, 2005 | 11:33 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Well $900 the Vortec Head and SDPC Vortec intake is prolly the best bang for the buck. Figure in Getting you heads reworked, parts and then a porting your intake or buying an aftermarket you prolly still come out better with the SDPC combo. If i could afford it I would be all over the vortec TPI. Good Luck
Old May 20, 2005 | 01:58 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
If you have no power after 4000 than you have a lot more wrong with your motor than heads. I am running the sister heads to your 081s, the 416s (same 305 1.84/1.5 58cc head but not center bolt valve covers) and I am shifting at 6000+ on my stealth rammed 327. Peak hp is around 6200. The TPI is your big brick wall to making any kind of revs -- you can have great heads and the helmholtz tuned runner setup is still going to give max cylinder fill at like 4800 rpms and then die.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
