high revving trouble
Old May 22, 2005 | 10:43 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
My formula 350 is strange. When I drive around town and everwhere else it feel normel. But when ever I floor it it will surge and choke like it want to die but will go away if i drive it normel after i do that. If i floor it on the highway it will be fine if i am going at highway speed I will not feel it surge and try to die. Thanks
Old May 29, 2005 | 09:04 AM
Vader's Avatar
Lacking further description, it sounds as if it might be experiencing a typical lean condition at throttle tip-in. That can be due to low fuel pressure, incorrect TPS setting, incorrect minimum air position setting, low idle RPM, and can be made worse by inadequate spark advance, vacuum leaks, intake tract leaks around the MAF, dirty TB, general state of tune, and probably other things I'm overlooking.
Pac J
May 17, 2020 10:44 AM
David Frans
Oct 31, 2015 08:12 PM
Giocio
Oct 1, 2015 12:20 PM
Lmancha96
Sep 25, 2015 08:11 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
