TPS voltage
Old May 24, 2005 | 11:18 AM
Allan Dollaway's Avatar
Car: 1988 trans am
Engine: 305tpi
TPS voltage
I read a past post about testing your knock sensor. Key on wire off makes 5 volts.Wire on sensor,probe back of plug and should be about 2.5 volts. Mine shows 9 volts on both sides of the test. It just started having intermitent knock problems and shows the ESC code. It is the original at 120000 miles,its a 86 305 TPI.Does this sound like a problem with voltage to anyone?? Thanks Allan
Old May 24, 2005 | 08:57 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well Alan, are you talking about the TPS or the knock sensor?
Check your title to your post.
Old May 24, 2005 | 09:42 PM
Car: 1988 trans am
Engine: 305tpi
oops,yes that is for the knock sensor.sorry
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
