Removed air pump, have a Q
Old May 29, 2005 | 06:07 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
how the heck do you get that pipe behind the motor out that ran to the driver side air tubes? it's loose and dangly now.
from underneath?
i bought some 1/4" pipe pulgs for the exhaust maifolds from home depot
just gotta put them in
put in the air pump delete pulley, but really don't need it if you route the belts like a 5.7l TBI in my Blazer, same brackets and all.
Ohh well
i used a sawzall to get some of the fittings cut off, most came right off with a 14mm wrench, talk about lucky.
the old pump was a little tight, definately compared to the delete pulley
next thing is to put the cat delete pipe in when i do the SFC's.
so what did everyone else do with that tube by the rear of the motor?
Old May 29, 2005 | 08:36 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Not sure if you're working on a 2nd gen F-Body or a Blazer, but I think what you're referring to on my '89 IROC goes to the Cat.
Old May 30, 2005 | 08:11 AM
Don 79 TA's Avatar
Engine: TPI
no, working on her 88 formula 350
i referenced my blazer cause i looked under that hood, had the mounting brackets, and locations of air, water pump, alt, and PS and tensioner
but i got a great deal on the air pump delete pulley, so really didn't matter to me, just referencing that incase someone else wants to remove the pump, don't really need that delete pulley afterall.
also, there were two electrical connections on this gadet that attached to the back of the air pump (it sits right behind the AC compressor). these lines went to these valves, so do we loeave them disconnected?
i took the valves off the gadget and just connected them up. looks like it was an electronic type of vacuum control for the air pump valves.
that damm pipe that routes around the back of the motor for the other side is what has me puzzled. i'll have to look at it from underneath the car, it's totally loose now.
going to put the 1/4" plugs in in a few mins, then cap off the divertor valve that goes down to the cat till the pipe comes in.
Old May 30, 2005 | 08:16 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Pull it as far as it will go to one side and fire up the sawzall again, then pull it further and cut, repeat as needed.
Old May 30, 2005 | 01:41 PM
Don 79 TA's Avatar
Engine: TPI
yeah, thats what i thought about doing,
also have a flexable shaft on for the dremel so i may use that as well.
all i can say is it's damm annoying how burried it is.
Old May 31, 2005 | 05:03 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
i had to pull the damn motor to get that stupid pipe out
Old May 31, 2005 | 07:26 PM
Don 79 TA's Avatar
Engine: TPI
thats what i was fearing, it just seemed burried in there
and since it pissed me off to no end
i WANT it out lol
i will probably put the new dremel kits to use.
i am now on a mission..........
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
mcquigg
Aug 13, 2015 02:26 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
