Its all about flow!! whats holding you back....
Old Jul 23, 2005 | 01:56 PM
  #51
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Originally posted by BC GTA
Ok I can see that now. The connecting rods do not bolt to the center of the crankshaft. Rather they bolt to journels offset from the center of the crankshaft. So at this point the bottom of the connecting rods are moving through a larger circle than the crankshaft. While only 1 stoke in 4 is an intake stroke it occures at some degree less than in direct proportion to the crankshaft RPM. Thanks for explaining that.
So these heads are able to intake all that the engine can physically pull in. Why then would you need to port the heads or have bigger intake ports and valves?
Short answer: Engines work in a vacuum (without an SC or turbo anyway). Every part in the intake path creates resistance and a pressure drop results from the resistance on the air. Porting/polishing, better heads, better intakes, etc all help reduce the resistance and help to drop the resulting vacumm pressure somewhere closer to ambient. More air pressure = more HP.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
jrdturbo
Mar 31, 2016 02:58 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
Briandrex
Oct 5, 2015 06:20 AM
