distributor servicing
Old Jun 17, 2005 | 02:39 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
I bought a new distributor with an external coil, to replace my in-cap unit. Well I was cleaning and testing it before I install it and the cap/rotor have some buildup and corrosion on them so I was going to just get a new set for it. Well I couldn't figure out how to get the rotor off. Does it come off?
Old Jun 17, 2005 | 04:13 PM
91Z28-350's Avatar
I better respond before Vader digs this up in 4 years....
Just pull.
Old Jun 17, 2005 | 04:47 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
I already tried that
Old Jun 18, 2005 | 09:19 AM
91Z28-350's Avatar
Eat some spinach.
Tap it with a rubber mallot. Heat it with a hair dryer. It just slides off, but can sieze up. If that don't work, snap the rotor off and cut off the remaining plastic. Slip some anti-sieze in there when you put a new rotor on.
Old Jun 20, 2005 | 09:17 AM
Svelte_SS's Avatar
Engine: 5.7L TPI
Ok I finally got the stock rotor off, only after soaking it down with some liquid wrench. It was totally rusted on there.
Is there any way to test the ignition module to see if it's good? I looked in both my chilton and haynes' and they only tell how to test the coil...
Also, I noticed some small holes with screens in them in the bottom of the distributor. It seems like these would let moisture up into the distributor (a bad thing). Should I seal these up with grease or something?
Old Jun 20, 2005 | 09:30 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Didn't spend any time reading it, but the chart in this post will probably show how to test the module.
The screened holes are vents, they are to let the moisture OUT as the engine bay/distributor heats up.
Only problem you will have is humidity, supposedly the "vented" distributors (as opposed to the earlier HEI that doesn't have vents) allow for longer change interval of the cap/rotor. You have humidity issues either way, so having those vents is not doing any harm.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
Damon
Sep 26, 2015 04:29 PM
