low fuel psi - bad fuel pump?
Old Jun 19, 2005 | 05:28 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
My fuel pressure is normally 45 - 50 psi, but now it's 34-40 psi. It runs 35 at 4000 rpm and and stutters. I replaced the fuel filter, but it didn't help. I get 13.41v at the fuel pump connection at the fuel pump relay. I also have been gettting codes for the MAF 33,34,36. It have a broken connector and I have had the low signal from the MAF intermitently since I bought the car. The too high and burn off codes are recent. I think the problem is a bad fuel pump, but I hope you can tell me it's something else. How can I be sure it's the fuel pump?
Old Jun 19, 2005 | 05:44 PM
dyeager353's Avatar
Car: many
Engine: many
Transmission: many
there are many variables at the issue. I just say that cause it makes me look smart. A weak pressure regulator is a possibility.
Old Jun 19, 2005 | 06:06 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
The pressure regulator is adjustable. I can back it out until it gets to 40 psi and then the psi goes down with further turns out. I think this is because 40 is all the pump can put out.
Old Jun 19, 2005 | 09:47 PM
suh weet's Avatar
Car: 1991 Z28 1LE
Engine: LB9
Transmission: WC T-5
To see if it is the regulator, clamp off the fuel return line and check pressure. If it is still low, it is the pump. I just had to replace my pump. It actually isn't that bad of a job. Just take your time.
Old Jun 20, 2005 | 08:37 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
The pressure shot up so I only have change the regulator. Thanks for the feedback.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
