Speed Density - Air filter off the TB or in the box?
Old Jun 23, 2005 | 09:24 AM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
For the 90-92 guys... Would it be better to just leave the air filters alone and run that restrictive factory box or yank all of that out and run a universal filter on the end of the throttle body? I'm kind of torn as you'd get a lot of hot air running right off the tb - but the factory box is so thin... What do you guys all do?
Old Jun 23, 2005 | 10:27 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Modify the stock box to use a bigger air inlet and duct it inot the fender.
Or build some type of cold air kit for it.
Either one fo those choices is alot better then the simple filter stabbed on the end of the TB.
later
Jeremy
Old Jun 23, 2005 | 10:48 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
The Camaro air filters are already in a "cold air" spot, Trans Am boy.
Old Jun 23, 2005 | 11:07 AM
3.8TransAM's Avatar
*kicks synapsis in the junk*
U merely misunderstood what I posted :-P lol
Yes true, I fubared there.
Your better bet is to keep the airbox and open up the baffles under the filters and swap in quality filter replacments.
Okay with u now Synapsis? lol
later
Jeremy
Old Jun 23, 2005 | 11:29 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Much better. Here's a cookie.
Old Jun 23, 2005 | 01:28 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
Sounds good. I'll see what I come up with then.
Old Jun 23, 2005 | 05:12 PM
3.8TransAM's Avatar
How'd u know chocolate chip is my favorite?
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Steve78LT
Feb 24, 2016 12:15 AM
86Base
Aug 8, 2015 01:34 PM
