My heads are at 60cc now. I am running the thin copper FelPro head gasket.
Any idea on my compression ratio?
This is on a stock 1988 L98 short block.
Please define "thin" What is the compressed thickness of the copper head "templates"? I hesitate to use the term "gasket", since it probably won't be one of those for very long.
With exact head gasket compressed thickness, deck height, piston dome/dish volume, bore, gasket bore, and chamber volume, I can give you a nearly exact static compression ratio.
Or, you can find it for yourself:
Engine Calculations.xls If you can use an Excel spreadsheet, it's fairly close.
FelPro preflattened copper head gasket.
.039" compresed thickness.
Stock short block. Stock pistons, untouched.
I'll take a WAG. How about 9.4:1.
Tags blown, calculate, calculating, compressioin, compression, comrpession, gasket, head, heads, l98, milled, milling, ratio
