tbi to tpi head questio
Old Jun 26, 2005 | 08:13 PM
kirkm76's Avatar
I am contemplating a TPI swap and I am wondering if a stock speed density tpi will will work with my tbi heads. I know they will bolt up, I am refering to tuning mainly. I want to do as little tuning as possible. The motor is probably going to end up in a Caprice daily driver (1991) and the TPI is mainly for show, plus I like the bottom end grunt of TPI for this. So long as I aM AROUND STOCK tpi HP levels I'll be happy. Its an L05 now.
Old Jun 26, 2005 | 10:15 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The 193s are good heads for your use and will be fine for the power level you seek. They flow right in line with the 083s. A little less on the intake but a little better on the exhaust (the weak point of all small block heads). Upgrade the cam to a F-body LT1 and you will be happy.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
gta90
Sep 15, 2015 04:00 PM
Sanjay
Aug 12, 2015 03:41 PM
