help
Old Jul 11, 2005 | 11:43 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
help
just wanted to see if anyone can help me out. i have a 383 HSR with 180 afr heads, .503/.510 lift cam with 1.6 rockers. it was running ok (needs to be fine tuned) i replaced the stock throtle body with a 58mm bbk and i gutted and descreened the maf. started it back up and it ran like crap. started to pop thru the intake. i thought i messed up the maf by cutting out the cooling fins so i purchased another one (btw i am not getting any codes from the ses) with the new maf it still is doing the same thing. i checked fuel psi which is at 40. checked timing which i set at 6* and it still is there. anyone know what i should check for next. i wasnt having this problem until i swaped the tb's. i also readjusted the iac and tps althought i did have a problem with the tps (i had to bend the back metel arm to get it to adjust to .54 v) HELP
Old Jul 12, 2005 | 12:14 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Does it continuously pop through the intake? Or at idle? Or just when moving the throttle?
If continuous - maybe there's a gaping hole in the intake tube from the MAF to the TB.
If only when moving the throttle, maybe from the combination of a 383, HSR, 58mm TB, big heads, big cam, and a stock chip's acceleration enrichment settings. Only way to adjust that is by PROM burning.
Old Jul 12, 2005 | 12:19 PM
smokefan's Avatar
i have a custom prom burnt for the set up. he said by changing the tb form stock to the 58mm shouldnt effect the tune. is this correct. if not what should i change in the tune since i have moates ostrich unit and i can emulate
Old Jul 12, 2005 | 01:40 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
Put the stock TB back on, see what happens. Let us know
