305 guys what head gasket are you using?need to know NOW
Old Jul 20, 2005 | 09:08 PM
V6camaroman's Avatar
well guys i have my heads back from the machine shop. got ques on the head gaskets though. i ordered a set of SCE metal head gaskets that have a compressed thickness of .015 but the bore of the gaskets are much larger than the stock 305 block bore. summit racing says these will work on my 305. the machine shop guys who built my heads says they wont. who should i believe? when you set the gaskets on the block there is about an 1/8" different between the block bore and the gasket bore. there is much less on a set of stock 305 gaskets. what should i do. 305 guys what head gaskets do you run? i wanted a thinner gasket to run
Old Jul 20, 2005 | 11:11 PM
TTT
Old Jul 21, 2005 | 01:01 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
I bought Sealed powers head gasket.
Old Jul 22, 2005 | 03:07 AM
billyhoss's Avatar
iam running a set of fel pro gaskets that measure that same 0.015 compressed and seam to be doing fine, they too were a steel shim gasket as they called them, part # fpp-1094
Old Jul 22, 2005 | 11:12 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I also ran the Felpro 1094 gasket on my 305, it is listed for the 350 but I had no issues with it on the 305.
Old Jul 22, 2005 | 11:58 AM
billyhoss's Avatar
iam running vortec heads so thats why iam using that gasket, i know of a few others using it also on there 305`s
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
Street Lethal
Aug 14, 2015 08:25 PM
