LT1 Intake
Old Jul 25, 2005 | 05:06 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
LT1 Intake
I have a 305 tpi thatis quite quckly turning into a road oiling fix or repair daily car. I have arranged to pick up a 350 block in 2 weekends from my friend. Out of a 95 truck, its in his 89 tbi tfruck currently. I already have a lt1 intake and want to use his serpentine set-up. It is the same as the 92 serpentine set-up except for the idler, which I can get the right one. My question is, I have heard problems with fitting the intake with the idler on both set-ups. Is this truth or myth?
Old Jul 26, 2005 | 07:26 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
The only problem I had was clearance issues with the TPS and IAC connectors. 5 minutes with the Dremel solved that issue.
Old Jul 27, 2005 | 06:57 AM
305TA85's Avatar
cool, I forgot to mention there is also a nitrous plate making the throttle body stick out an extra 5/8"
New2Chevy
Sep 28, 2015 12:35 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
toronto formula
Sep 10, 2015 07:31 AM
L0tuS
Sep 4, 2015 11:16 PM
