Name That Sensor, Vacumline, and coolant path...
Old Jul 29, 2005 | 01:59 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
Im having some trouble figuring out what sensor this is and where it goes. Also, I have a vacum line that I am unsure of where to put it.(Pic Below)
Finally, I need to figure out how to run my heater core lines. I am putting a 89 TPI system on my 91 RS. I already deleted the Heater control valve. What fitting should I run a hose from to go to the firewall for the heater. I am also going to do the throttle body coolant bypass if that matters.
Old Jul 29, 2005 | 04:56 PM
rsn932's Avatar
oil pressure sending unit. it goes on the rear china wall of the engine. if you are standing in front of the car, it is just to the right of the distributor.
Old Jul 29, 2005 | 09:17 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
The giant vacuum line goes from a port on the TB over to the charcoal canister.
Old Jul 29, 2005 | 11:31 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Yes, the larger of the two goes to the port on the TB on the TPS side just below the larger air breather port. The othe smaller line goes to a port under the TB to the right of the IAC sometimes tee'd with the A/C ,and or the EGR solenoid vacuum lines.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
BWilcox
Sep 20, 2015 12:19 PM
FormulasOnly
Sep 10, 2015 09:07 PM
