temp sensor location
Old Aug 2, 2005 | 11:13 PM
bonz's Avatar
Car: 89 GTA
Just wanted to make sure te location of this, I know there is one on the intake manifold, is the other under the exhaust manifold. Also is the temp sensor on the intake manifold just for the fans or does it also send info to the computer.
THANKS
Old Aug 3, 2005 | 03:58 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Drvr side between 1 and 3 is the temp sensor for the guages.
Temp sensor for the ecm is on the front of the intake.
Temp sensor for the secondary fans is between 5 and 7 on the pass side.
later
Jeremy
Old Aug 4, 2005 | 10:48 PM
bonz's Avatar
Car: 89 GTA
Do you know what size of socket the passanger side sensor is. I bought a hypertech fan switch and that sensor is a 13/16 but the sensor in the block seems bigger, its hard to get to though.
Old Aug 6, 2005 | 09:10 PM
TexasB4C's Avatar
Car: 92 Camaro B4C 350
are both "head" temp sensors the same part number?
Old Aug 7, 2005 | 02:15 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
later
Jeremy
There's only one secondary fan, it's temp sensor is between 6 and 8 on the passenger side.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
tonys91rs
Sep 2, 2015 07:07 PM
