Hard Start & Oil Pressure Gauge Problems
Old Aug 8, 2005 | 02:49 PM
ASR GUNS's Avatar
Car: 88 Iroc Z28
Engine: 5.7 TPI
I have a 88 with TPI somethimes it will start right up but most time I have to crank the hell out of it ( 45 + secs. ) and when is starts it stumbles then slowly smooths out? Also my oil pressure gauge bouces all over 30 to off the scale, this is all the time. I know one doesn't have anything to do with the other. Any suggestions?
Old Aug 8, 2005 | 03:08 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Do some searches.
The first problem could be caused by a bunch of things. Have you checked your fuel pressure? Done any ignition work lately?
The second problem is most likely a failing pressure sending unit (site on the back of the block behind the oil filter). Easy swap, ~$15-$20.
M
Old Aug 8, 2005 | 03:14 PM
ASR GUNS's Avatar
Car: 88 Iroc Z28
Engine: 5.7 TPI
tune up cap, rotor, wires, plugs, but didn't help. Runs great once it starts.
Old Aug 8, 2005 | 07:28 PM
CheezX's Avatar
Replace the fuel pump relay (should hear the fuel pump for 2 seconds when you turn the key to the on position) and oil pressure sending unit (this is also a backup switch for the relay, turns on the fuel pump when oil pressure is above 4psi).
Old Aug 8, 2005 | 08:08 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I had the same problem, minus the oil pressure gage problems. I had leaky injectors. Next time it's cranking and cranking, give the pedal a 75% push and see if it starts quicker.
Old Aug 9, 2005 | 05:09 AM
ASR GUNS's Avatar
Car: 88 Iroc Z28
Engine: 5.7 TPI
As soon as you turn the key you can hear the pump run breifly.
I will change the oil sending unit this weekend.
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
