Replacing the Fuel Pump
Old Aug 25, 2005 | 10:20 PM
Galen W Rouse's Avatar
Car: 1983 Trans Am 1986 Trans Am WS6 1985 Fiero SE
Engine: 83' LG4 305 86' 5.0 TPI 85' 2.5 Fiero
I am going to replace the fuel pump in my 86 TPI WS6 T/A this weekend. This car had sat for about 4 years and now that I have the computer straightened out, I only get about 22 PSI at the rail. Replaced the filter also. The car runs great when fuel from an outside source is supplied. Anyway, Has anyone found an easier way than the manuel calls for ? Or is it that the rear end needs to be moved. The exhaust is already out to install a new system. Thank You, Piston Dude
Old Aug 25, 2005 | 10:41 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did you block the return line to verify the regulator is A-ok?
Otherwise search for "hack job" or "access panel" and you'll get the gist of another alternative
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
