Fuel Injection (TPI) Wiring Question
Old Aug 26, 2005 | 08:08 PM
Bob53's Avatar
Car: 1991 Z28
Engine: 5.7
I'm in the process of replacing the exhaust manifold gaskets
fuel injectors, and fuel pressure regulator on my 1991 Z28
5.7. 125K miles. I didn't mark the injector plugs on the harness for re-assembly. I'm not sure which plug goes on which injector. Does it matter?, or do they fire at the same time? Any help appreciated.
Old Aug 26, 2005 | 08:27 PM
Scheister's Avatar
Car: 85 IROC
on my 305 upon reassembly it was obvious which connectors went to which injectors. the length of the harness let me know.
Old Aug 26, 2005 | 08:45 PM
Bob53's Avatar
Car: 1991 Z28
Engine: 5.7
On the wiring harness that holds the injectors plugs, there are two plugs with equal length of wire. (two sets for each side)Makes it a bit confusing. On the 5.7 anyway. They should space the plugs on the wiring harness to go with each injector. That would make it easier. Of course if it doesn't matter which plug goes on which injector, it's a wash.
Old Aug 27, 2005 | 01:06 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
On the same side it doesn't matter.
The right side injectors are all driven by one ECM driver to ground, one 10amp fuse protects those 4 injectors. The left side is identical.
Old Aug 27, 2005 | 07:30 AM
Bob53's Avatar
Car: 1991 Z28
Engine: 5.7
Thanks for the info!!!!
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
