Rocker arms
Old Aug 28, 2005 | 09:51 AM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Rocker arms
Can I use non aligning roller rockers in a L98 350 TPI engine? Or do I have to use them with guideplates?
Old Aug 28, 2005 | 10:07 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Non-aligning rockers require guide plates.
Old Aug 28, 2005 | 10:14 AM
Guest
Guest
Posts: n/a
Thats not exactly true. Some heads have a narrow pushrod hole (looks like a slot) instead of a large round hole. Those heads dont need guideplates, the hole in the head keeps the pushrod in place. Seems like GM was somewhat random on which engines got what heads, even in later years. Best to take a look at what you've got and go from there.
Old Aug 28, 2005 | 10:42 AM
Car: '87 Iroc-Z
Thank You very much
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
