check my math? please.
Old Sep 2, 2005 | 07:02 AM
mean57's Avatar
Car: 87 gta
would this cam with 1.6 rockers work for my application.
Product Line: Crane CompuCam Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-5,500 RPM
Intake Duration 050 inch Lift: 214
Exhaust Duration 050 inch Lift: 220
Duration at 050 inch Lift: 214 int./220 exh.
Advertised Intake Duration: 270
Advertised Exhaust Duration: 276
Advertised Duration: 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.452
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.465
Valve Lift with Factory Rocker Arm Ratio: 0.452 int./0.465 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash (in): 0.000
Exhaust Valve Lash (in): 0.000
Computer Controlled: Yes
Grind Number: 2032
CARB EO Number: D-225-22
Quantity: Sold individually.
i have slp cold air intake. twin 52 t/b, ported and siamesed plenum, AS&M semi siamesed large tube runners and a big mouth manifold. (stock heads )
longtube header exhaust out the bottem.
was wondering if the 1.6 rockers would be to much?
Old Sep 2, 2005 | 02:50 PM
mean57's Avatar
Car: 87 gta
ttt
Old Sep 2, 2005 | 04:24 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
You are looking at .496 ex lift with 1.6 rockers, not sure if stock heads will like that unless you change out the springs.
Old Sep 2, 2005 | 06:20 PM
mean57's Avatar
Car: 87 gta
that's what i needed to know. thanks
mean57
skeltor
Feb 2, 2016 10:37 AM
Jonesyfxr
Sep 26, 2015 02:08 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
