searching idle
Old Sep 4, 2005 | 09:33 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
searching idle
My car seems to have a searching idle...like itll idle for alil bit and then raise and idle there for awhile...then ill rev and itll go back to down. It seems this only happens when the timings at 12...but it runs best then. I checked and tightened all the intake bolts, my ignition grounds are good, i cleaned the iac, no codes.
any suggestions?
Old Sep 4, 2005 | 09:38 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did this begin with the rebuilt engine? If so, did you use a larger cam? Or just a stock build on the engine?
Old Sep 4, 2005 | 10:48 AM
Car: 1991 Z28
Engine: SBC
car had a comps cam in it....then i rebuilt and reused the cam
Old Sep 4, 2005 | 03:43 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Assume it worked fine before the rebuild?
I see you seem to have a host of other issues with it now...did it all start after the new motor?
Might be best to list'em all in one thread...
Also, by any chance did you have to jump the car to get it going with the new motor? If the battery is weak and the engine is running off Alternator power without a decently charged battery, you will get a high/low idle surge.
I notice in another post you mentioned checking the grounds, after a rebuild, things are usually painted, which inhibits good contact...so you may need to scrape some paint behind the heads where all the sensor and ECM ground tie...as well as make sure the small braided strap is in from intake??.head to the firewal on the pass side rear of the engine.
Old Sep 4, 2005 | 04:02 PM
Car: 1991 Z28
Engine: SBC
Ok i solved my big problem today...it was throwing code 43 and my fan wasnt going on...found out my plug for knock sensor and the fan swtich were mixed up lol...so the car runs good now...still no fans..i think the wire is dead. Neway..i KNOW the connection to my battery is bad...the positvie side on the battery is pretty much stripped out and doesnt connect very well...so i think i just found my problem: . but neway Yes the cam was fine when it was pulled (a machine shop rebuilt this for me, he said the cam was perfectly fine)
Old Sep 4, 2005 | 04:03 PM
Car: 1991 Z28
Engine: SBC
and yes i checked my grounds..not need to take a look at those on the back of my heads though..
and about listing em all in 1 thread...sorry i just post them as they show up...i kinda just take 1 problem at a time..
Old Sep 4, 2005 | 04:06 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That's cool, but a lot of times some things show common issues...so if all problems can be seen, could point to one thing...maybe not, but maybe so
Looks like you've got some things going, and you need to fix the broken stuff them move along to the others.
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
1fast91
Sep 8, 2015 01:48 PM
Slush92RS
Sep 2, 2015 08:56 PM
SlowAZ28
Sep 2, 2015 05:19 AM
