testing fuel injectors
Old Sep 5, 2005 | 04:51 PM
SFX099's Avatar
Car: '95 Trans- Am
Engine: 5.7, Baby
I am trying to find a missfire, how can I test a fuel injector though?
Thanks,
Steve
Old Sep 5, 2005 | 05:11 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Well.
U have 2 ways, depending on what is easiest, 3 technically.
First ohm the injectors, theyshould all be within a ohm or so of each other.
If the miss is solid and not intermittent:
Then u can pull injector leads one at a time
Or u can pull plug leads one at a time.
Obvioulsy if u have a dead cylinder, when u pull that one you should get no change and it should get worse if you remove the fuel/spark from an otherwise good cylinder
edit: If u find something suspect or have quick pressure drop even with the return line blocked, pull the fuel rail up and pressurize the system, any leaks/drips shoudl be evident then
later
Jeremy
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
