Making my fuel pressure regulater
Old Sep 14, 2005 | 06:27 PM
Tweaked's Avatar
Car: 88 t/a red w/body kit
Engine: 305tpi...355 carbed
I keep hearing about people doing it but i can't find any info on how to do it and how well it works. how do you make the stock fuel pressure regulater adjustable and what do i need to buy???
Old Sep 14, 2005 | 07:44 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
there are pictures around here.
but, the simple answer is a small nut 6 or 8mm?, small bolt for the nut (1" long?) a thin flat shim alittle smaller and thinner than the electrical box knock outs
take the top off the stock one, dent inside out just a little to make extra room for the shim and a little extra so it looks like it is almost mounded out.
drill a small hole for the bolt in the top, weld the small nut on top of the reg. start the bolt in the top of the reg. make sure it screws in
put that shim ontop of the internal diaphram, reinstall the cover, set psi
Old Sep 15, 2005 | 02:16 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
MAke sure you have a good safety torque when u do it.
Also Iw ould recommend at least getting a new diaphragm for the regulator, just due to age and condition. No sense in doing it twice, unless u know it has been replaced recently
later
Jeremy
Old Sep 15, 2005 | 04:49 PM
Tweaked's Avatar
Great... do i need to weld it or can i get away with sodering it or somthing else
Old Sep 15, 2005 | 08:25 PM
Engine: ls1, LB9
I would weld it. some have done other things but, welding is the strongest.
Old Sep 16, 2005 | 11:17 AM
Ackattack's Avatar
Car: 99 Corvette/72 GMC
Engine: LS1/L98
Transmission: M6/700R4
Axle/Gears: 3.42/3.73
sounds like a lot of work to save $50 (especially if you don't have a welder)
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
