Code 33 and bad module
Old Sep 14, 2005 | 09:13 PM
Kwiksilverz28's Avatar
Within the last 100 miles I have replaced the distributor with a new Accel Billet dist, accel coil, tach adapter, fuel pump, AFPR, and serviced the injectors. Car threw code 33, then died. Replaced ignition module after some hunting, and runs fine now. Warmed up and no codes. Scanner looks ok. I have not driven it yet.
Is there anyways that a failing module could trigger a code 33, or is there some way a code 33 issue could kill a module? Summit is sending me a new module, but I am looking for 100% reliability in this car....
Old Sep 15, 2005 | 02:21 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Do a search for code 33 and other MAF related issues.
Should point you to the proper factory flow chart that I know has been posted here.
But in a general answer to your question, an ignition module usually wont cause a MAF related error code.
A failing MAF, bad ground, faulty TPS, or dieing relay could however.
later
Jeremy
Old Sep 15, 2005 | 05:32 AM
I have the flow charts. The 2 should not correlate, but I was wondering if I missed something....
chazman
Aug 28, 2018 03:25 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 18, 2015 02:28 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
