tpi.. whats the difference in years
Old Sep 14, 2005 | 11:06 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
tpi.. whats the difference in years..will the intake fit
i was reading and was wondering will a 90-92 tpi fit on a car with older heads.. i saw that to put a pre 87 on an later model you need shims.. pleaze help. so basically will the intake fit on my heads..i want to do tpi but i hear that the 90-92 is the better or the tpi systems.. thanks..
Old Sep 18, 2005 | 12:07 PM
Doug Gulley's Avatar
Car: A Black One
Engine: 383 Chevy
Transmission: Retro T56... :>)
The angle of the 2 center intake bolts change sometime over the years but I'm not exactly sure when. The older intakes will swap with the newer one (and vice versa) by elongating the 2 center intake bolt holes.
85-89 TPI used the MAF setup and 90-92 used the MAP (speed density) setup. Basis of either setup has been hotly debated. Either setup is a good setup.
Various parts are different between the years. 85 - 88 use a 9th injector for the cold start. 89 deleted this and used the 8 injectors themselves to enrichen the cold start (choke).
The MAF system uses the sensor to measure airflow and the MAP sensor calculates airflow. Both are good systems. The MAF system will tolerate more changes (cam, heads, headers, etc) without the need for a new chip. It won't be optimim just like swapping a new carb without tuning the jets, etc. It will run, just not to the max potential. If you get into prom tuning, that won't be an issue though.
Just make sure you have a matched system.
Old Sep 18, 2005 | 11:47 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
thanks..randall..
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
neekolzun
Aug 24, 2015 04:59 PM
TheExaminer
Aug 19, 2015 10:07 PM
