runs like crap until,
Old Sep 21, 2005 | 01:32 PM
jamesmidnight's Avatar
Car: 89 Formula 350
The car runs fine until it heats up. If i take off the wire going to the no.6 or no.4 injector the car will run. Once it is placed back on, the car will stall and not start. If taken back off the car will start and run. Both wires dont have to come off at the same time either or will make the car run smoother.
Old Sep 21, 2005 | 03:01 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Ohm all your injectors.
Good factory should be 16-17ohm. I believe below 12 is considered inoperable.
Basically u have one(or more) with low impedance. It overheats your injector driver and will cause it to shut down.
SVO are around 14ohm range.
If u have say 15,12,1,8,8 etc you need a new set.
Depending on whic ones are on your car, u may need a new set anyhow as to what your describing sounds to me like the elctrical windings are gone anyhow.
Ohm them out and let us know what u find.
later
Jeremy
eightsixseven
Dec 16, 2024 01:50 PM
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
perZ
Aug 21, 2015 05:51 PM
92camaroJoe
Aug 13, 2015 06:07 AM
