flat tappet cam in my tpi...
Old Sep 21, 2005 | 05:00 PM
ktacam's Avatar
Car: 85 z28
Engine: 305 tpi (I got screwed, supposed 350)
Transmission: 700r4, b&m shiftkit
I pulled the heads off of my engine the other day to do valve jobs. When I pulled them I pulled one of the lifters. To my suprise the lifters were not rollers. The engine is supposed to be from an 87.
Does anyone know if 87 engines were rollers?
I am thinking the engine may be the stock 85 but did they have tpi in 85?
Also what would be a good flat tappet cam to use with the stock computer?
Any help would be great.
Old Sep 21, 2005 | 08:02 PM
Damon's Avatar
87-up is supposed to be the roller cam motors. I've found exceptions to this rule but never on a TPI engine. Is the block designed for roller lifters?
How to tell..... flat tappet lifters will sit sunk down in their bores about 1/4" in the valve-closed position if it's a roller cam block (earlier flat tappet blocks they sit flush with the top of the lifter bore). Also, there will be 3 bosses down the spine of the lifter valley- they will be drilled and tapped to take a bolt. These bosses are normally used to hold down the lifter "spider" which retains factory-style roller lifters.
If you have a roller block but a flat tappet cam and lifters in it, it's possible somebody swapped the cam out for a flat tappet or..... it's a replacement engine from who knows where. If it's not a roller cam block you definitely don't have an original 1987 engine.
Old Sep 21, 2005 | 08:33 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
First year for TPI is 85'
Old Sep 21, 2005 | 11:33 PM
ktacam's Avatar
Car: 85 z28
I never thought to look for the lifter hold down holes, I will check for that as soon as possible. I still have one head on so I will check and see if they sit level. So basicly if 8 of the lifters are sunken in 1/4 inch the block is a roller?
Old Sep 22, 2005 | 04:07 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
My '86 TPI isnt roller I was looking at the Summit TPI cam for mine since its for pretty much stock 305 TPI. Its a nice upgrade but nothing radical.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Jorlain
Oct 8, 2015 01:57 AM
Ironhead38
Sep 7, 2015 02:26 PM
TheExaminer
Sep 6, 2015 11:40 PM
