TBI to TPI tech article?
Old Sep 24, 2005 | 07:24 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
where'd it go, i thought there was on around, i got a chance to get a TPI set up(anything i want from a donor car) for $200 so im looking to see what i need.
Old Sep 25, 2005 | 07:55 AM
92MaroRS's Avatar
No One knows what happened to it?
Old Sep 25, 2005 | 04:43 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
you will need the ecm, and the wiring harness and the plenum, fule rail, fuel pressure regulator, injectors, lower intake, and the intake runners. The Throttle Body, all the plastic vacuum lines. Also be sure to leave the throttle linkage plate on the TB cause youll need it. Id steal the electric fan setup too off the car as well as the fan relay which should be on the right hand side of the radiator support tucked near the right headlight area. Geez, I hope someone else chimes in cause I am sure I am forgettng some things. Oh, youll need a fuel pump setup from the tpi car too. TBI uses less fuel pressure than Multiport injection.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
evilstuie
Jan 9, 2020 08:29 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Sanjay
Aug 12, 2015 03:41 PM
