fuel injector help?
Old Oct 14, 2005 | 11:04 PM
lil_grover's Avatar
Car: 1989 GTA
Engine: 350 tpi
fuel injector help?
i was just wondering what brand of fuel injectors are the best and what size i should run on a stock 350 tpi with exhaust. or if there is any other mods i should do before the injectors.
thanks for the help
Old Oct 14, 2005 | 11:50 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
if your injectors are ohm tested and fine(I think about 16) then do something else with your money.
port plenum
tune-up
afpr
lcarbs
tires
box your lca
shift kit
gears
your money is better spent elsewhere
What is your exact purpose for the car(drag racing or street??)
Old Oct 15, 2005 | 01:09 PM
lil_grover's Avatar
Car: 1989 GTA
Engine: 350 tpi
i am buildin it for the street and just a little amount of drag racing(1/8 mile). i dont know what some of them abbreviations are though( ya i know i'm a newb) could you please define them for me and tell me what the best improvement to do would be horsepower wise. thanks for the help
Old Oct 15, 2005 | 02:23 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
afpr
=adjustable fuel pressure regulator(on the fuel rail) under $100 and probably 5-10hp
lcarbs
=lower control arm relocation brackets(search this, under $100 and helps traction)
box your lca
= lower control arm(helps with traction and free is your can find someone to weld)
port plenum
= about 5-10hp
if youi want big gains, go nitrous
if you don't have alot of money, do the stuff noted
HP is addictive!!!!!!!!!!!!
Old Oct 15, 2005 | 09:13 PM
lil_grover's Avatar
Car: 1989 GTA
Engine: 350 tpi
thanks for the help i really appreciate it
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
