Off Idle hesitation
Old Oct 19, 2005 | 10:36 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Off Idle hesitation
Got the idle speed, TPS and timing all adjusted, now with the car in gear if you hit the gas hard, it hesitates real bad, falls on its face,
any ideas?
Old Oct 19, 2005 | 05:51 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
check the fuel pressure with a gauge. get a book and it will tell you what the specs should be. 37-40 at idle, and should spike to near 50 psi under heavy throttle, then go back down and hold steaady around 37-40 again.
Old Oct 20, 2005 | 10:24 AM
Car: 1971 Camaro
Engine: 427
Fuel Pressure is good, running MAgna fuel reg. set ar 47 psi, any less shows lean on the af gauge
85 Jimmy
Sep 30, 2015 07:56 AM
webeeZ28
Sep 14, 2015 12:00 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Ranbo108
Sep 9, 2015 12:20 PM
IROCtometal
Sep 9, 2015 10:01 AM
