Egr
Old Oct 22, 2005 | 08:20 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Egr
Can someone post a picture of how the egr should be set up on a 92 camaro Z28 with a 350. Im putting mine back on to see if the car will run better... The egr was kinda half assed when it was on the car before with some cut tubing that lead to nowhere...so can someone please post a picture
thanks
Old Oct 22, 2005 | 10:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Might be awhile, since it's under the plenum and somewhat hidden.
May want to keep searching and maybe you'll get lucky with a pic.
Old Oct 22, 2005 | 11:10 PM
Car: 1991 Z28
Engine: SBC
wait wait....****...then what did i remove..
i know what your talking about...that IS the egr..but then what did i remove..( i just realized this)
heres a pic of what i need fixed..
http://community.webshots.com/photo/...3489636PsKKav#
as you can see, the tubes going too it wernt even connected when i recieved the car..
what is it and how does it effect the car running wise?
Old Oct 22, 2005 | 11:33 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
That is your AIR diverter valve. Controls wheether the air injection goes to the exhaust manifolds, catalytic converter, or is vented to the atmosphere
Old Oct 22, 2005 | 11:39 PM
Car: 1991 Z28
Engine: SBC
would it effect the cars ability to run at all w/o it?
i wanted to put mine back on but idk how to set it up...the tubes were all butchered when i got the car...
Old Oct 29, 2005 | 01:24 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
shouldnt affect driveability
Old Oct 31, 2005 | 04:56 PM
FearThisGTA's Avatar
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
Mine has been gone for several years as well as the ap, too. Of course I dont have to worry about emissions testing either. So, ya might wanna takethat into consideration as well, ok. Good Luck.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
