How feasible is low 12s on the Long Tube runner design????
Old Nov 2, 2005 | 03:20 PM
  #51
Guest
Guest
Posts: n/a
Thats not entirely true. An extreme example would be a car that drops from 5000 to 1000 after a shift. No power down there. Its going to somewhat depend on the car as to where the ideal shift point falls. Get the right gear, stall, tires... yea 7k is wasting effort and time.
Old Nov 2, 2005 | 03:26 PM
  #52
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by 6SpeedTA95
Dude its IMPOSSIBLE for an intake change alone to affect the RPM/MPH correlation. You changed something else or misread your tach. If you wanna know how/why this could happen start your own thread. It is NOT possible, I dont wanna clutter this up anymore with this RPM vs MPH stuff.
Originally posted by Abubaca
Not to add clutter, but he's correct. it is IMPOSSIBLE for an intake to make such a change. 100 HP or 1000HP, both would still reach the same MPH at the same RPM, assuming everything else stayed constant.
i didnt read the whole thread, so it might have been mentioned already, but its possible to change.
two words:
torque converter.
athough honestly, 1000rpm diff is alot..... on a loose stall that stalled at 5200 in my friends car, it stalled at 5500 after adding over 100 rear wheel hp.
Old Nov 2, 2005 | 03:32 PM
  #53
smithtc's Avatar
You've gotta have an intake to support the heads and cam. If you try to rev a factory TPI system to 7k you'll do yourself no good beyond 5500 the system just doesn't breath.
If I recall correctly Stock Eliminator Cars with 305 were shifting at 7000 rpm...with TPI. So, it depends.
All of these absolute, Impossible, answers etc. around here
Old Nov 2, 2005 | 03:54 PM
  #54
Shagwell's Avatar
Car: projects.......
agreed on the intake. How much air can you suck through a garden hose? how 'bout an 1/4 fuel line?... you can only get what you give...
- 7k isn't wasting anything. If your geared forand your combination makes power at 7k, then weeeeee haaaa...
My 4161 lb vert(stereo, me 1/4 tank) is a land barge, still knocked down 11.7@130 all motor. Got 20mpg highway and 17 town carbed...I don't think 7k is wasting time or effort.
- Also agree..hp is fuel. The more of it you can burn, the more power you can make. Bigger cubes will rev if you can get burn air/fuel to make it. My dads blown big block turns 9600-10k every pass in the 1/8...
Old Nov 2, 2005 | 04:35 PM
  #55
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
On a 305 I could see you getting 6k out of it but that would be a stretch I would think. I've never heard of someone purposefully building/revving a TPI motor with the factory intake to 7k maybe they did but thats nuts...
A torque converter would not make a 1000 rpm difference unless the converter wasn't functioning. Even then the intake manifold has no relation to the gears/gearing of a vehicle. Torque converter might allow it to build revs slightly faster due to more power, but in reality thats only because its not locked up, the ratio's of the engine RPM to speed hasn't changed simply the converter allowing the engine to turn slightly higher RPM. If the converter were locked up there would be no difference. ON a manual transmission car you'd not have any difference unless you had a slipping clutch but thats faulty equipment. Why is it so hard to grasp the fact that an intake manifold does not affect the gearing of the vehicle? Gearing is related to engine speed and mph, torque converters are as well but a properly workin converter would not yield that kind of a difference.
Old Nov 2, 2005 | 04:52 PM
  #56
smithtc's Avatar
Racing is a bit different than normal driving...and Stock Eliminator racing is an extreme.
I was attempting to point out that it is POSSIBLE to have an altered RPM based on something as simple as an intake change, depending on certain variables. Why is it so hard to grasp that it is a possibility? You've already contradicted yourself. I didn't mention anything as far as specifics or specific cases, except that a TC can be affected when power levels change...and its something that needs to be accounted for. Simple as that. Take it for what its worth.
Time to move on...
Old Nov 2, 2005 | 05:26 PM
  #57
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Time to move on...
Do you have a link or anything so I can read about this? I would also like to know what kinda power they were making turning a motor that high with that intake.
Old Nov 2, 2005 | 06:42 PM
  #58
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i'm not sure if that was directed to me or not, but i was just saying that any motor can be built to rev and make power to 7K rpms... depends on cam heads intake of course, but the bottom end is where it is. it needs to be built to take that abuse. so a 327 or a 406 can be made to turn 7K rpms.. cubes doesnt really make a difference.
Old Nov 2, 2005 | 06:48 PM
  #59
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
and the fact still remains... gears and tire size make the speed and rpms. simple physics stuff. but only in theorectical conditions where there is just engine speed directly rotating the gears... no torque converter slippage or any other slippages
a torque converter will allow slip and thus cuz the engine to change rpms at a given speed. i can crawl 20mph up a steep hill at 2000rpms in first or 2500rpms in first, depends where i put the pedal.. the tq is slipping.
thats the only thing that changes tho that can cause rpms at a speed to change. and the only thing that can cuz how a torque converter acts is the engine power output where cam/heads/intake change that. so basically, a intake swap could cause a power difference and change how the converter acts. which will/could change ur rpms at speeds. but still, gearing and tire size affects rpm vs speed (mph) directly
Old Nov 2, 2005 | 07:25 PM
  #60
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Yeah thats true, from my reading though I gather that shorter stroke motors generally are more durable and can rev higher because it keeps piston velocities down. I've always been under the impression that this was correct. I've read a couple books on motor building and a lot of mags and they all seem to point to shorter stroke bigger bore for higher revving motors. Is this incorrect?
Old Nov 2, 2005 | 09:21 PM
  #61
Guest
Guest
Posts: n/a
Nope, not directed at you... you beat me to the submit button.
Old Nov 3, 2005 | 12:16 AM
  #62
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i dont have it with me but i do have a magazine.. i think hot rod that did a study on hp and torque from short stroke big bore motors vs long stroke smaller bore and also short rod vs long rod.
i have always heard destroked motors or short stroke big bore motors revved higher more easily than others.
i do know that long rods allow for more piston dwell at top dead center or so i read. i'll have to dig that up and see.
as for TPI motors, i'm not sure what they like best... would TPI intake have different power curves for short stroke big bore motors than long stroke small bore motors? what about rod lengths? with the long runners of TPI, you would want to beable to draw in a air intake charge with as little effort as possible. would more dwell at TDC help the combustion process and draw in a charge better than shorter rods? i guess it wouldnt make a difference cuz piston travel is still of the same stroke length
Old Nov 3, 2005 | 07:28 AM
  #63
Shagwell's Avatar
Hot Rod's comparison was ok, but they went for same ci, same heads same cam. One motor was short stroke/big bore, the other was bigger stroke/smaller bore. - W/ out heads and cam packages suited for the application, its kind of a wash...
Pro stockers run the big bore, short stroke motors because larger bore takes more advantage of a good cylinder head.(claim made by Warren Johnson). If he says he sees a power difference on the dyno, I believe him. Plus the short stroke lets them buz them, then shift 4 times, maintaining that high hp/high rpm power curve.
later, justin...
Old Nov 3, 2005 | 01:21 PM
  #64
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Well from what I've heard an engine with a small bore is more prone to valve shrouding problems which can have a negative effect on cylinder filling
but as far as fast long tube cars you can go wayy faster than 12s with boost TurboedTPI is running 10.90s with long tubes and boost just food for thought
Old Nov 3, 2005 | 02:16 PM
  #65
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Yeah with FI thats true, but I wanna stay NA.
Old Nov 3, 2005 | 05:37 PM
  #66
Car: 89 Formula
I hear ya I'm an all motor guy myself but you cant argue with results
Old Nov 4, 2005 | 09:55 PM
  #67
Shagwell's Avatar
I love motor. Thats why I haven't put that powerstroke turbo on. Something about compression and a big cam just gets my blood flowing... - I kinda like my super powershot.
- My car has sticker that says N/A. It was always there for "naturally aspirated", but since I left it after the bottle I just told my friends it now means nitrous assisted...
Old Nov 4, 2005 | 10:36 PM
  #68
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
hahah thats nice
as much as i love the sound of a big rumbling n/a motor, i love the whine of superchargers and the whistles of turbos... the blow off just makes kids go WHOA
Old Nov 5, 2005 | 12:38 PM
  #69
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
hahah thats nice
Ever heard a Kenny Bell Cobra Mustang ..for a mustang its pretty damn sweet
Old Nov 5, 2005 | 12:48 PM
  #70
Car: 89 Formula
Gotta love BOOOOOOSSSST
Old Nov 5, 2005 | 01:02 PM
  #71
Abubaca's Avatar
As far as the RPM goes, given the conditions that were being discussed, the TC wouldn't be an issue, and RPMs wouldn't change.
Generally speaking, I suppose it IS possible, but not is this case.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
beast94
Aug 20, 2015 06:44 AM
