tpi engine harness to firewall interchange
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
tpi engine harness, what years interchange
I have an 1988 dash wiring in my car and a long long while back had a stupid attack and cut out the TPI to go carb. Well now I want to go back to TPI and want to know what year tpi engine wiring will hook right back up to the fire wall conector besides the 88 harness? Will 85 to 89 swap or is it just 87 to 89?
Just remember when u get the painless one you dont have all the connectors for all of the sensors. I think its missing some of the emissions sensor hook ups, not sure but I know it's missing a few of the required ones for a completely stock setup sensor wise.
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Car: 88 iroc-z
Engine: 5.7 zz4
Transmission: megaraptor 700r4
Axle/Gears: 3.73 10 bolt posi
87-89 will bolt right in...i have an 88 the guy befor me hacked the wiring,i got a 89 harness from e bay works perfect ....but remember 89 does not have a cold start inj,and the oil press switch is different every thing else is the same , also the 87-89 harnesses are one with the rest of the engine compartment harness so the wipers blower motor etc are all included
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
