MAP Sensor Identification
Old Nov 7, 2005 | 06:48 AM
mrrilla's Avatar
Car: 1939 Chevy Coupe
Engine: 383 TPI, Dart Pro1 180cc heads, etc
How can I identify a MAP Sensor by the markings on the case? None of the case markings match the 8 digit AC Delco #. Is there a cross reference chart for the 5.7L MAP Sensors to other GM MAP Sensors?
Old Nov 7, 2005 | 10:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: MAP Sensor Identification
There are hot stamped numbers on the front ledge above the connector. The TPI MAP will have either a 460 or 039 stamped on it (numbers from memory, hope I have them correct). This is the same sensor that is used on many SD GM systems, cars & trucks.
The other method of ID is the connector insert. They are color coded, green and black are the 039 and 460 sensors. IIRC, orange being 2 bar. Then gray and/or blue for a CCC baro sensor. And red for ??
RBob.
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
