MY TPI'S MAKING BUMPING NOISES
Old Nov 12, 2005 | 06:36 AM
HOZZ4's Avatar
Car: 1988 CHEVROLET IROC-Z
Engine: 5.7 TUNED PORT INJECTION
Transmission: 700R4 AUTOMATIC
I HAVE REBUILT 5.7 TPI WITH THIS UNUSUAL PROBLEM. WHEN CAR IDLES DOWN AND DURING NORMAL DRIVING CONDITIONS AFTER THE WARM-UP, IT MAKES THIS SHUDDERING BUMPING NOISE CAUSING LOSS OF POWER AND SUCH. IT ISN'T AN IGNITION PROBLEM BECAUSE I'VE CHECKED THOROUGHLY. PLEASE TALK TO ME AND TELL ME WHAT YOU THINK.
Old Nov 12, 2005 | 07:41 AM
Vader's Avatar
Low power and shudder at low RPM? If the ignition is intact, consider checking compression, fuel delivery, and the valve train.
Lacking any further information, pinpointing the problem can be difficult.
Old Nov 12, 2005 | 08:12 AM
Vader's Avatar
Re: MY TPI'S MAKING BUMPING NOISES
Originally posted by HOZZ4
THE ENGINE IS BRAND-NEW. THE FUEL PRESSURE IS AT 46 PSI. I CAN ONLY ASSUME MY VALVE TRAIN WOULD BE GOOD SINCE THE ENGINE IS NEW. (ABOUT 12000 MILES ON IT NOW.) .
If there is vibration and studder at idle, there is likely at least one dead or weak cylinder. Try to isolate which cylinder(s) is weak using a power balance test, then concentrate on that cylinder.
After the engine is running at normal operating temperature, carefully remove the spark plug wires one at a time. Plug boot pliers are very helpful for this, since the spark will try to find any path to ground (you). You may find it easier to remove the wires from the distributor, but there is a chance of crossfire as a result of this practice. Removing them from the spark plugs is a little safer.
As a spark plug wire is removed, the engine idle should change. There should be more shaking and a drop in RPM before the ISC can compensate. If you experience a change, install the wire back onto the plug and move on to the next one. If you discover one that makes little or no change in teh idle, you have found a dead or weak cylinder.
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
Sanjay
Aug 12, 2015 03:41 PM
BlackBoulder
Aug 11, 2015 11:15 PM
BrianI
Aug 9, 2015 11:52 AM
