smog delete
Old Nov 14, 2005 | 11:33 AM
philllk's Avatar
Car: 1986 trans am
Engine: 350 carburated
Transmission: 700 r4
smog delete
Had a basket case 1986 TA, started out as 305 carb now has a 350. What are the correct belt numbers and what is the routing?
One is a serpintine the other 2 are v-belts. Without the air pump>>
Old Nov 16, 2005 | 07:39 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
I have serpentine Smog Delete on my '88. I followed the tech article on the main page.
EDIT: Right Here is the one for serpentine. But I think your looking for a VBelt one, in which case I can't help, sorry.
Old Nov 16, 2005 | 10:56 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: smog delete
Yes your car came with 3 belts. You just don't put the one for the air pump back on. All will be fine if you've deleted your CAT already.
Your wide belt goes around the alternator and water pump.
The long V-belt goes around the W/P, the A/C, and the P/S.
The short one gets deleted.
Any Autozone should be able to give you the part numbers for all the belts you need. From the part number you can deduce the size of the belt.
jaridjohn
Oct 5, 2015 07:01 AM
