I forgot where these go! Need some help
Old Nov 20, 2005 | 05:40 PM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
Almost done with slow head gasket job. I labeled most parts but forgot to differentiate bolts from the runners and plenum. There are 3 sizes in the picture, I have some in the base. Which sizes go where? In taking it apart at night I didn't notice they were different. Second is a support bar for something. I thought it was for the alt. but I have one there. The last one is a bracket with a bend in it. Thanks
Attached Thumbnails I forgot where these go!  Need some help-mystery-parts.jpg
Old Nov 20, 2005 | 06:04 PM
Vader's Avatar
For the TPI base and runner bolts, try just setting the bolts in the holes (without threading them in) and arrange them so that the same amount of thread is exposed on each bolt.
That flat bracket with the large hole is a factory lifting bracket. Usually, one is installed at the rear of one head and at the water pump on the opposite corner.
The long one looks like the brace for the A/C compressor.
Old Nov 20, 2005 | 06:07 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
The lifting bracket is on the passenger side head for both of my engines.
Old Nov 20, 2005 | 07:26 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
extra parts
Old Nov 20, 2005 | 08:01 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Process of elimination.....
One of the long bolts goes to the far rear of the plenum on the drivers side. I know b/c i lost it before. I learned to take a cardboard box and stab all my bolts in the box one at a time labeleing them whem i take them off. Being cardboard you can just cricle the bolt and write which bolt it is and its location. Too loate for that now but good luck.
Old Nov 25, 2005 | 09:29 AM
jetblast's Avatar
Car: 91 z28 convertible
Transmission: 5 speed
Faguedabooutit It'll make the car run faster
Old Nov 25, 2005 | 09:54 AM
6SpeedTA95's Avatar
Car: BMW 335i
Engine: N55 turbo 6
Originally posted by Dialed_In
extra parts
I lol'd
Old Nov 25, 2005 | 04:04 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I agree with Vader here...get that brace in place or you could have some problems...the lift bracket can be left off, but be sure to store it away somewhere you'll remember in 2 - 3 years when & if the engine needs to be pulled or you'll have a real fun time with it.
Old Nov 29, 2005 | 07:30 PM
Shagwell's Avatar
Car: projects.......
lift brackets? you don't need no stinkin' lift brackets.... 2 2-1/2 inch 3/8 bolts, one for the fron t of one head, back of the other, log chain in the middle......yes, the rod is the a/c brace. -
Old Dec 2, 2005 | 05:28 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I ditched my AC brace years ago, along with the alternator brace. Never had a problem with anything.
Old Dec 2, 2005 | 05:29 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
i am thinking about just leaving it off, i am glad to hear there is no problem from it
Old Dec 3, 2005 | 11:47 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I would put the brace back on its not that hard to do. Dont worry about the engine lift just put it in a spot u can find it later if u need it.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
BWilcox
Sep 20, 2015 12:19 PM
codeysabatini
Sep 20, 2015 11:36 AM
