Granatelli adjustable MAF
Old Nov 27, 2005 | 10:08 PM
TMFK's Avatar
Car: 85 Z28
Engine: ZZ-3,Mini-Ram, Holley EFI
Transmission: 700-R4
Axle/Gears: Hawks 8.8
Has anyone used or heard any results on the Granatelli adjustable MAF (for 85-89 TPI) over a stock MAF. I think my OEM MAF is a restiction. Thanks for your help!!!!!!!
File Type: bmp
Old Nov 28, 2005 | 10:06 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I had that thing and returned it. It was a complete waste of money and did not even work.
Old Nov 28, 2005 | 10:11 PM
TMFK's Avatar
Car: 85 Z28
what do you mean?stalling? check engine light? poor performance? thanks for your feedback.
Old Nov 29, 2005 | 07:20 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I believe that the GMAF is no bigger in diameter than the stock MAFs. And yes, the GMAF is very expensive. The attraction of the GMAF is that it is "tunable".
If you are worried about the MAF being an air restriction, well it is. But you can remove both screens and have it flow 658 CFM as compared to stock flow of 518 CFM, that is an improvement of 27%.
658 CFM should be enough air to make about 506 Hp.
518 CFM should be able to make 398 Hp.
FWIW: I am using a descreened MAF on my 395 cu.in. stroker.
Old Nov 29, 2005 | 09:57 PM
TMFK's Avatar
Car: 85 Z28
Thanks for you help!
Old Nov 29, 2005 | 10:03 PM
TMFK's Avatar
Car: 85 Z28
J-money
Jan 4, 2019 09:45 AM
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
1nastygta
Sep 24, 2015 08:58 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
